| Yes they will. I have Green Leaf's dual fan asymmetric nozzles on 5-way TeeJet nozzles bodies. I running GL's "6" tips @ 40 psi putting down 20 gpa @ 11-12 moh. ith AIM command I can drop the pressure more but don't like the slower "cycle" o the AIM though haven't seen any negative affects in kill. I' looking to go to "8"s next year & run 30psi. I believe that is what Cliff is running on his sprayer
I like the drift control of the GLs. I have teeJet Twin Jets on the same nozzle bodies, "brown" tips, & they put out way more drift at the same pressure & gpa. The GL dual fan asymmetric tips are the only AI tip approved to be used with AIM Comman, or at least were when I purchased ours.
Another feature I like with the GLs is tht one tip points forward & one points down. The holder is designed so the tips can be run either way. GL recomends alternating direction of tips on your boom. They claim this creates a "swirling" effect that allows for better coverage.
Edited by boog 6/28/2017 11:35
