SESD | In one day, you and her, bad. Especially if load and unload by hand. Probably not even feasible in one day that way. If you do several hundred a day for several days, or even 2 days, that will make a big difference. Just for a visual. On our 48' step deck semi trailer, stacked 9 rows high, it's about 650 bales at the most IIRC. On our 26' gooseneck stacked 8 high that's about 335 bales. So, that gives ya an idea how big of stack you will be looking at. | |
- How bad will it be to pick up 1,000 small bales? - BryceH : 6/25/2017 22:50
- RE: How bad will it be to pick up 1,000 small bales? - 6030TGUY : 6/25/2017 23:00
- RE: How bad will it be to pick up 1,000 small bales? - JRthefarmer : 6/25/2017 23:00
- RE: How bad will it be to pick up 1,000 small bales? - Haleiwa : 6/25/2017 23:02
- RE: How bad will it be to pick up 1,000 small bales? - dpilot83 : 6/25/2017 23:05
- RE: How bad will it be to pick up 1,000 small bales? - brud : 6/26/2017 05:17
- RE: How bad will it be to pick up 1,000 small bales? - okfarmboy : 6/26/2017 08:38
- RE: How bad will it be to pick up 1,000 small bales? - School Of Hard Knock : 6/26/2017 08:44
- RE: How bad will it be to pick up 1,000 small bales? - gene_champ : 6/26/2017 12:27
- RE: How bad will it be to pick up 1,000 small bales? - swne : 6/26/2017 13:51
- RE: How bad will it be to pick up 1,000 small bales? - marlinpain : 6/26/2017 18:37
- RE: How bad will it be to pick up 1,000 small bales? - 5288 : 6/26/2017 20:22
- RE: How bad will it be to pick up 1,000 small bales? - Don ald : 6/27/2017 08:57
- RE: How bad will it be to pick up 1,000 small bales? - Stormwatcher : 6/27/2017 12:04
- RE: How bad will it be to pick up 1,000 small bales? - cho : 6/27/2017 15:23
