Butterfield, MN | No, the same sensor is using (using the one on the sprayers), but Raven developed a new machine tune set between old and new machines, as they changed the logic (normally open vs. normally closed) on disengage switches on these machines in 2014, so they added machine tune sets in for calibrating with the same name, other than the new ones say 2014 at the end. This can be confusing, since a lot of times when the old style disengage switches fail on earlier machines (and they did) you would have to replace them with the new ones and completely recalibrate the steering on the machine so you could select the tune set with 2014 in the name so it would work with the new switch. They also have a different pin-out, so either an adapter cable has to be installed on the machine, or if you have a weatherpack pin pusher, you can just swap two of the pins around on the plug going to the new switch and get by that way too. | |
