Evansville, WI | What rates of each would you like to see of each when the main target weed would be marestail? Would be spraying ground going to corn and soybeans the following spring?
I have seen recommendations for using a product like rangestar or weedmaster at 24 to 32 ounces, 24 ounces provides about a pint of LV4 and about 6 ounces of Banvel. Are those rates to low, if they are to low what rates of each would you like to see? Would there be any benefit to adding metribuzin to the mix?
What adjuvants do you like to see with a 2-4D/Dicamba combination in the fall?
Planning on pre's of Zidua Pro for soybeans and metolachlor/mesotrione for corn in the spring. | |
