Central Kansas | It's in a 2188,SF1.with a ITC globe with a Brown Box. It has a awful time finding the next swath. If you manually drive it to the next swath and get on the center line, it will hold quite well. It seems to ALWAYS want to "steer to the right" momentary after you have manually lined it up with the center line and hit the resume switch. I have changed the set up numbers but nothing seems to help.
Anyone run this set up in a combine and either have the same problems or have the secret recipe of numbers to help find it's swath?
As a side note, run this same set in a two wheel drive tractor and it works very well.
Would you think that the rear wheel steering of a combine make it tough to preform properly?
Edited by trakman 6/24/2017 18:19
