Calhoun County, IL | I believe you will need another bracket that goes on the inside of the roof and then have to drill the holes in the roof so you can bolt them together.
I think the parts you'll need are (#3) RE155713 Bracket, (#2) R163378 Supports , (#1) 19M7862 Bolts and (#4) 19M7866 Bolts but you may double check with your dealer to be sure.
Edited by Ridge Runner 6/20/2017 18:44
(Cab Bracket and Wiring crop.jpg)
Attachments ---------------- Cab Bracket and Wiring crop.jpg (30KB - 93 downloads)
