central iowa | Grootendorst - 6/15/2017 20:25
I just put an Integra and a Directcommand kit in a sprayer and can't get the autoswath to work. When I enter a sprayed area it it shuts off too soon and when I enter an unsprayed area it turns on too slow, I've played with the look aheads but they just made it worse. Also when spraying in manual mode and I shut all the boom sections off except for one it beeps and says rate controller not responding and it turns off the paint on the monitor, but it continues to spray out of the section. The Integra is up to date and I think the liquid product control module is to. Anyone have any ideas or solutions? Thanks, Grootendorst
do you have the measurements for the tractor correct??
what about the measurement from the drawbar to the spray tips???
If they are not correct then the look aheads will just be fighting the configuration |
