| Attempting to import Planting Rx's into our pro 700 from SMS. I've spent a lot of time on it and feel close but haven't been able to plant with it yet. My problem right now seems to stem from having to use a separate flash drive to import Rx. I create the Rx on SMS and save it to a blank CNH approved flash drive and create a new cn1 folder or SMS does it I should say. I then take out my main flash from 700 insert Rx flash, key on machine, go into performance Rx setup, and load it in. I'm able to see my map on the coverage screen and toggle it on/off. However this is not the flash drive I want to log data on so I try shutting off, swapping drives, turn on, no Rx. I try leaving on swapping drives, both pro 700 and planter get mad at me. I try it faster, still gets mad. I finally key it all off, unplug everything, plug back in and go plant flat rate. It seems the monitor should be able to store the RX, is there a setting I'm missing or should I import it differently. TIA | |
