| If you right click on your seeding or planting tab after you have created a map and trace the boundary I think this will work for you. So create map, notice what your acres are and right click on the tree and select trace boundary, it will think a little bit. You then can click contour or grid over on the right and it should get you the correct coverage acres. I know there are other ways to do it but this works for me. Little tough to explain if you need pictures let me know. | |
