roaming | Dillsburg 560 D - 6/9/2017 19:24
It needs to be changed to can based yield. Should be able to change it in toolbox or work condition. Does your display have the set up wizard? If so you can go through there and set everything up as needed.
Toolbox > Yield. Select CAN-based instead of YMIU. Combines don't have a setup wizard, so you'll have to set this manually. Also check Toolbox > Disp and make sure the Current Vehicle is correct. |
