Winkler, Manitoba Canada | JAR - 6/10/2017 18:28
Yes. It drops down to 350 psi. Max was around 2300 psi when steering into stops.
Those pressures seem fairly normal if your were measuring the pressure line and not the load sense line.
Did you measure the pressure in the load sense line that runs from the autosteer valve to the steering orbitrol? You want to observe the pressure as you steer manually as well as when the autosteer is engaged.
In this line steering manually should yield pressures from more or less 0 to 2300psi. Autosteering should not produce significant readings at this location
Edited by WTW 6/12/2017 08:26
