Posted 6/1/2017 06:49 (#6048238 - in reply to #6046953) Subject: RE: auto swath doesn't work
Bernard, IA
If you don't want to create a new event go to the home screen, then the big wrench on the upper right hand side. Then go to the barn at the bottom and find the field you are in and highlight it. Then the little wrench in the middle, and the push the clear bounds button. It will act like nothing happened but once you go back to your run screen everything should Wouk fine.
