ec. nebr. | You may have a universal harness already in a tractor you are using the ATU in. Depends how you placed the current wiring, if it would be easy to move? If you ran the wire for the globe up the corner post, easier to get another harness. I had one in my sprayer that was a pain to remove, so had Ag Express make a connector [cut the harness]for just the wires going to the globe. Then had them make a duplicate of the one for the globe in the tractor. Those remain with each machine, but the main harness is used in several other machines, because it is real easy to move now. You don't say model of combine, but if there is a kit for the steering wheel mtg. it will work. Also the hub in steeriong Atu may need changed for right splines. Does combine have the 3 prong 12 volt recepticale for power out? You will need a monitor bracket of some kind and a gloge mtg. bracket. | |
