roaming | CycloneZ - 5/28/2017 19:21
I'm new to using a Pro700 for autopilot. How do I shift an existing line and save it as a new line? I need to shift lines for striptill but cannot figure out how to save a shifted line under a different name.
You can't exactly save a shifted line. You'll need to engage on the shifted line, then create a new AB line while you're engaged and driving on the shifted line. That will create a new line at the shifted position. Then you can cancel the Re-mark on the shifted line and it will go back to the original position, and you're left with two lines - one at the original position and the new one, parallel to the original and at the new position. |
