North Dakota | First things first, if you do a search on newagtalk you will find a large number of threads about the BRIDGE FAULT.
Before you send in the control check you power and ground. DO NOT plug it into a cigarette lighter, The "lower bridge fault" is almost always caused by power issues. Try to connect the power direct to the battery if you can, a power post inside the cab is the easiest to connect to. Connecting to a switched source is acceptable if is a proper connection to a circuit without a fan or similar motor running on it. | |
