North Dakota | The problem with the solution pump was a poor connection in the fuse box. All the fuses were good and reading correct voltage but we took electric leaner and cleaned the connections good and then it started to work. We were only getting 3 volts to the pump and we should of been gettiing 12 volts and we tested the the wire going to the solenoid from the cab and it had continuity. So we went back to the fuse box cleaned it and the pump worked. | |
