SC WI | Raven and Norac both have lovers and haters. Biggest thing is pick the one that integrates with your spray controller. If running raven viper pro, envisio pro, viper 4 or raven ISO through a VT through another system a raven system will tie in without adding any more cab clutter. . Raven and Norac will both operate on VT. Norac is owned by Topcon now and seamlessly works with their rate controller any X30 moniter. It will work on some others with an unlock.
The key to autoboom happiness is having the system calibrated and adjusted properly for the setup you put it on. Also knowing the systems limitations and not expecting it to do things it cant. | |
