Williamsburg, Iowa | RCT
I work for Kinze.
If you're looking at bulk fill, the 3650 is the older version with the 3600 and 3660 bulk fill having the current air seed delivery systems. The 3650 is no longer made.
Between the 3600 and 3660, the 3660 is the heavier frame with more flex, larger bulk tanks (hydraulic drive only) and a rock shaft under the hitch (ideal for replanting). So it depends on what specifically you're looking for. Both models come with vac and mechanical meters. Check out the current vac meter, customers feel if performs very well. You can learn more about 3600 and 3660 on kinze.com or by visiting your nearest Kinze dealer who should also have a Seed Meter Test Stand to demonstrate the meters.
Thanks for checking out Kinze!
Susie Veatch | |
