Appomattox/Fredericksburg, VA | When you say functions correctly is it reading yield? Works without the mobile processor as a yield monitor? Give us some more information. Harvest doc properly setup to document? You could put the 2630 in but would have to verify software version of the moisture sensor. Would also use a different harness from the corner post to the display.
Edited by Glenn Dye 5/25/2017 19:54
