Madision County, IL | It does use a pressure transducer and seems to be working correctly based upon readings seen on the display when turning the steering wheel.
If I understand how this should work, when auto steering, the steering orbital load sense sends a signal (change in oil pressure) to the auto steer valve that kicks out auto steer and allows manual steering.
Correct?
If the orbital LS wasn't working correctly, I couldn't steer the tractor manually. Correct?
Thank you for the input.
Edited by JAR 5/25/2017 22:41
