| jpwfranks - 5/23/2017 22:56
Thanks for the install manual WTW! The manual I had was an newer revision that I got from the trimble website, and the valve shown in it didn't has a LS check valve, but the valve shown in the manual you emailed me showed removing the LS check valve. Im going to go get a plug for where the check valve was, and Im pretty sure that will fix my problem!
Thanks for the help everyone!
John-Paul Franks
That was where I was leading. With that check valve left in there, the LS signal can't bleed off and it holds the pump on high pressure standby. |
