Posted 5/22/2017 19:13 (#6031805 - in reply to #6031797) Subject: RE: using glyphosate as tank cleaner?
You are right about the gly going on corn. Was thinking I would drain down completely and run a couple hundred gallons thru before even running the gly in the first place, just not completely sure if the Callisto in the Lexar needs to be neutralized also.
