SW Georgia | As a former AMS specialist, I have seen this problem many times. It could be a # of problems. The best thing to do is start with the cheapest parts to replace and seeing that you have a 20 series, I would start with all your fuses, relays, and the resume switch. A faulty resume switch will allow you to run sometimes and then times it will just not work. So replace any of those parts first. If you are still having probems, look at your CAN connector at the back of the tractor. Look for a disconnected wire or any rust on the pins. If no problems there, then chances are you will have a faulty steering valve.
I would say check your steering sensor, but since the 20 series doesn't have one don't bother.
Edited by ESBROCK10 5/25/2017 14:49
