Hennepin, IL | First try to reset modules on the diagnose screen, and possibly try a reboot. If you've done that, try replacing the harness between the display and the octopus harness for the module. Next try replacing the octopus harness. Last I'd try replacing the module. There's been multiple times I've suspected a bad module and it ended up being a harness. I did replace a module once, so it can happen. Just saying, try the cheap parts first. | |
