Search Forums | Classifieds (50) | Skins | Language
Spot Spray and Micro Proportional Valves
   Forums List -> Drone TalkMessage format
MidNight Mapper
Posted 5/16/2017 11:01 (#6019622)
Subject: Spot Spray and Micro Proportional Valves
Colorado and Oz
Saw this and figured some one on the UAS PA front might take interest in this device. I understand that heavy lift gas powered UAS for spot spraying rice and vege-fields is the go in Japan on this season.
FYI
MidNight Mapper
aka neil
Low hysteresis and a consistent lift-off current make the PFV series of 2-way proportional solenoid valves ideal for OEM liquid and gas applications where repeatable, accurate performance is key. Featuring stainless steel construction and an IP67 rating, these valves are top-in-class for both performance and construction.
Available both with and without onboard drive electronics, the PFV is ideal for users who have tight project deadlines, need to get to market quickly and require a plug-and-play device that can be up and running in a short amount of time.
Claim your free sample today!
https://enfieldtech.com/flow-control/
