roaming | 2388farmer - 5/14/2017 15:18
Yes R7 exports a zip with shp 4 files within it including a shp. Should I unzip the file or just leave it as a zip?
Does it need to be in a certain folder on the USB stick?
unzip so that you have the 4 individual files. place them all in a folder named Shapefile in the root of your USB stick. if you have multiple prescriptions, all the files go in that same folder together. the display will automatically figure out which files go together. |
