Posted 5/13/2017 18:06 (#6015688 - in reply to #6014929) Subject: RE: JD 4600 and 2630 multiple display with ISO planter question
Woodham, Ontario
Yes, if you setup the 4600 as implement viewer, you can view your planter on the 4600, you might have to push the planter VT (Virtual Terminal) over to the tractor from the 2630, using the NextVT button, which is hidden somewhere in the planter settings.
