Buxton, North Dakota | If there is a boundary and you are outside of it spraying, autoswath will not work properly. Either make a new boundary, or eliminate the one for the field. There is also a button in the Home-double ended wrench-barn-field name-wrench called "clear bounds" this will also reset things if things were working and all of a sudden quit or won't shut off. This will enable things to work again with no boundary. | |
