| Yes can be fixed but with her on the same account as you things will not back up only one of them will using the same account
To fix it from ringing on other units like your phone the iPad an so on you need to go into your setting go down to phone and where says ring on other devices that needs to be changed to or shut off
As far as backing up contacts photos notes an so on you need to go to iCloud under settings and shut if off as to back up | |
