Middle TN | from down the page a bit...
Played with it a little more today. Made several more field swaths, deleted old ones, made new ones from continuous driving and from boundaries.
Every time, same problem. "AS-265; no swath data available in the NAV controller..." when I try to engage on the second swath.
I can see the lines I need to follow, so today, I manually drove the line. Halfway around the "field" I was suddenly able to engage. Went back and tried to drive the initial pass. Could drive all but the last segment of that pass and then it wouldn't. So, last part of the first round and first part of the second round wouldn't work, but the rest of it does.
Surely someone else has had a similar issue and it's a setting I have wrong??? | |
