NE North Dakota | 2007 Ford Fusion. I am having a problem with the passenger front door. If you shut the door normally to hard the door will not latch and will just remain open. If you close the door gently or keep pushing it to in a sense "follow through" with it closing it closes and latches completely. Not sure where to start or how to fix. Door latch or latch pin do not look to have moved places at all.
Any advice is appreciated Thanks in advance
