| Sf3000, 450mhz radio. R series
My signal was going to rtk-x against a treeline which is understandable but it was taking until I got to the other end of the field to go back to RTK. Other tractor running same setup stayed on RTK in the whole field except for a couple seconds when against treeline. Tried swapping the black antannaes thinking one of them went bad, but that didn't make any difference. Next day put a different sf3000/450 on the tractor having issues and it stayed on rtk.
So I've ruled out the $195 black antennae. Could the 450 radio be going bad? Or something wrong with the sf3000? My globe that's having issue also has external coax ran from it to hook up to external antannae setup on dirtpan. | |
