MN | If you ar on primarily flat land you should be able to run a small amount of room in your sway blocks. Approximately 1/8 of an inch. One thing that you might want to do is take the pins out of the lift arms and put them in the float position to give you a little room when the tractor is pitching side to side and when the implement is moving up and down. This wont effect implement drift side to side but it will reduce the draft load from switching side to side. | |
