| Toolbox - GPS is where you enter the receiver to fixed axle offset. For steering, this is where all calculations are based. (Front axle on 4wd and rear axle on 2wd).
Toolbox - TC is where you enter the distance from the fixed axle to the drawbar pin. This is needed, as ISO Implements measure their application point/s back to the drawbar pin on the implement. This is normally setup in the VT Implement interface and if set up properly should also auto-populate in the Diagnostic - TC - TCPF page for reference. This page will also allow you to set a product latency.
