Search Forums | Classifieds (198) | Skins | Language
MN CORS Login
ShopTeacher
Posted 4/25/2017 21:22 (#5982331 - in reply to #5981297)
Subject: RE: MN CORS Login
NW MN
It will take a few days for MNDOT to get back to you with your login info. Unless something has changed in the last year you will need to make sub accounts for each unit if you want to run them on the network simultaneously. If you don't the first unit logged on will connect but the second will login and get bumped off and then try to log in again. Their FAQ will explain more.
