nw ohio | "max flow" means the valve that regulates the oil for the fan to run at the desired speed is all the way open. I think the first thing I would check is if you have the hydraulic flow for that remote high enough. After that, I would go through the wizard for full setup again if your monitor has them.
If that doesn't work, it might be a software glitch. One year on our 1250, nothing would turn on , and the tech had to reinstall a piece of software on the monitor.
good luck. | |
