Near Intersection of I-35 & I-90 Southern Mn. | When I used an Insight on a 4720, I also owned a Raven RGL500 light bar. I ran it beside the Insight and they complemented each other very well. It was completely stand alone although they both got their GPS from the same Phoenix 200. Since the Phoenix had two GPS outputs, one went to the Lightbar and the other to the Insight. I used the Light bar to get me on the correct set of rows. I used the SED pattern where you push a button when you get close to the headland, this does a ReCal from your current position to move over the swath width. This compensates each pass for any GPS drift especially with WAAS.
