Near Intersection of I-35 & I-90 Southern Mn. | mtbrights - 4/20/2017 18:53
There should be an "M" button for manual control of the servo valve. Go to manual adjust as necessary. Putting a manual speed in is a hassle for sure. Working from memory here but that's how the Integra has always been.
I create a special configuration that uses a Manual self-test speed. I name it "Test purposes Only Do not use to Spray". I pick this configuration and the manual speed comes along. For normal spraying I use my original configuration. |
