| So who's running one on a 2630 display? I was out tonight at a clients & they have a Cat 765C and the Horsch planter. We installed the Agri JD/Cat bridge system, 2630 & starfire 6000. I was surprised that the 2630 is reading the Can Bus on the Cat. I ended up shutting task controller off on the little C1000 monitor. Then shut off the original Greenstar brown box on 2630. Unplugged the iso for planter, plugged back in after a few & letting 2630 pull in the planter again & this time everything showed up. Implement was greyed out & had correct offsets. Was able to load the Rx & even section control doesn't appear to be mad that it has 24 rows. Says we have 16 & near as i can tell is its every row till it gets closer to the center. But it was raining so we couldn't go play.
Only thing I can't get is the split screen & on video on You Tube John has it split. Have the settings to JD split screen but No Joy.
Called the fellow that has the YouTube videos of one running by a 2630. His tech guy was setting up a new one & he couldn't get split screen to work either. Both his display & mine were on latest software so that may be some of it.
So just wondering if anyone else has some ideas
So anyone?? Anyone?? Bueller? Bueller? Bueller? | |
