SW MN | Fun when everyone just passed the buck on to the other guy. Good info from the other posters already, I have a couple things for both systems. First, I believe that the issue with clutching lies within the JD settings. Precision is the only company that I am aware of that actually clutches based off seeds planted. Therefore your JD monitor SHOULD clutch based solely off of coverage from a lift switch, whether there are seeds there or not. On the Precision side, you should have 2 smart connectors passing signal in on one side and repeating this data out the other. Verify that the second side is being utilized. If the smart connector is a gen 2 it will be flat and need an additional module to repeat the 37 pin signal. This should get you your seeding data. FYI...I have had better luck with gen 1 with repeating signal | |
