Posted 4/19/2017 22:59 (#5972521 - in reply to #5971895) Subject: RE: outback and raven
To run auto section control with the S2 you'd need to add an Outback Automate but, being it's just a lightbar, you won't be able to see where you've applied and where you haven't.
You'd need to update to an S3 or one of the current displays and add an AC110 for that - then you could remove the Raven controller altogether and run your auto rate/section control through the display.
