Posted 4/18/2017 07:27 (#5968860 - in reply to #5967833) Subject: RE: 20/20 with dickey john sensors not detecting a row.
NE Nebraska
Power on the planter harness should be 8 or 10 volts between b and c pins on the weatherpack connector, not 12. A gen 2 smart connector will have 10 volts. You moved the sensor and the problem followed or you jumped signal from problem row to good row and problem followed?
