Central Nebraska | Running an accuguide steering system and want to get gps speed to DJ display. Was able to connect to 12 pin deutsch navII connector to 9 pin serial on display harness and have gps on DJ display but when in the IntelliAg screen, there is no ground speed showing. Am able to bring ground spped to IntelliAg screen if we pull radar from the A-post and run it into the 4 pin amp connector on display harness but want to run Rx and clutch control which is not possible without gps. Is the 372 capable of sending simulated radar? Is there a setting in the DJ to show gps on both the DJ side and the IntelliAg run screen? | |
