roaming | greencountry - 4/16/2017 20:58
factory ready tractor but using ag leader steer command, 6500 receiver and integra for guidance. pro700 is running planter
In that case, the recommendation is to turn Overlap Control temporarily OFF before backing into a corner, then drive forward and turn Overlap Control back ON AFTER you pass the place where you turned it OFF. You can put an Overlap Control window on any Pro 700 Run Screen to make this easy. |
