| rubbed thru wires going thru cab floor........popped the fuse in the power strip......but not on the Raven.
However, now the meter valve calc/ ie flow screwed up...............Meter valve calc should be 171, can get to rate by dropping to 17......but after a round see on tank gauge no near enough.........
then tried changing speed calc to where raven has unit going 3x faster than actual tractor to get desired flow, but same result...........
apparently shorted wire froze meter valve?...........but didnteven pop fuse on back of Raven 440?.........or something internally on the raven itselve :(....
thanks for any thoughts in advance, have a great Easter. | |
