| Have a new 2630 on RTK this year in our JD 7820. Run AB curves on a couple fields that wind along waterways. Last couple of years with 2600 it would run those curves absolutely perfect one we set one. I mean they were dead on....it was like it was steering for the planter and not just the tractor.
This year, it wont work to well. It ll follow a curve we set but if it get to a point with even a moderate turn it leaves a large gap. Like its turning way to early? Tractor stays on the line but planter not even close.
No idea what i have set up different in this one vs last monitor. Went to curves setting under guidance and asks for implement in ground turning radius. 30' was in there but that cant be right for and 8 row planter? I unchecked the "smooth tight turns" box and it greyes out the turning radius number but that didnt seem to make any difference.
Im certain all offsets and measurements are accurate.
Any ideas? | |
