| Still no success on getting field iq to run on this machine. I've tried changing flowmeter, servo valve, and rate and control module. The servo valve is a 3 way valve one to boom the other to bypass. Apparently the midtech arc 6000 runs it that way but field iq can't seem to get it to work right. I should be running 40 psi at 15 gpa but I can only get it to 15 psi at 7 gpa. No clogged filters that I can find and pump is producing good flow. I've put 2 different powerheads on the servo valve. It's almost like it won't close the bypass enough to get full flow. My only other idea was to put a quarter turn valve in the bypass line and run it as inline servo. | |
