Posted 8/16/2006 05:44 (#36198 - in reply to #36092) Subject: RE: Jd2600 display mounting bracket
The movement is between the bracket that bolts to the moniter and the shaft that bracket mounts too. These new brackets have a spring loaded handle to adjust them up and down and back and forth. I believe the spring in there is where a majority of the movement is coming from.
