Search Forums | Classifieds (179) | Skins | Language
CASE hyd system
cjv
Posted 8/15/2006 08:19 (#35934)
Subject: CASE hyd system
I have an old CASE 3594 and the hyd system is giving me some problems.
I am trying to set it up to run my manure spreader, which involves operating the hyd orbit motor to drive the pump (10-15 gpm) and also the hyd regulating valve for the rate control system (about 1 gpm).
The problem is that I can't get it to run both functions from different remotes at the same time. I can't get the regulating valve to work at all if I put the orbit motor in the priority valve. If I put the reg valve in priority, it works fine until the Raven controller tells the hyd valve to move to change the rate, then the pump slows or stops.
Is there something wrong with this tractor, or some trick to setting it up? I can get it to work on my 7250, but not the old CASE.
Thanks.
