Posted 6/27/2008 10:54 (#405490 - in reply to #405471) Subject: Re: AFS Pro 600
roaming
Are you connecting the Garmin directly to the Pro 600, or are you connecting in to a connector on the cab harness? What GPS Connection Type did you select in the Pro 600? How have you configured your Garmin receiver? What is the adapter you're using?
